Teraz jest 28 października 2026, 08:29
 Tytuł: (E39) błędy w komputerze
PostNapisane: 11 października 2011, 20:42
Moje BMW: F10 535d +
auto to E39 520i, wyszły takie kwiatki :
1250
1250/P
0500
jesli ktoś ma dostep do kodów błędów ewentualnie wie co jest to prosiłbym o pomoc
 Tytuł: Re: (E39) błędy w komputerze
PostNapisane: 13 października 2011, 17:20
Moje BMW: e39 523i touring
Kod silnika: M52TUB25
Garaż: w trakcie budowy :)
Nie bede zakladal nowego tematu.Podlaczylem dzis swoja pod kompa. Ktoś pomorze w błędach ? :
Kod:
=========================================================================== error memory test    V1.41                                 BMW TI-433 Teepe =========================================================================== vehicle-identifikation-number:  WBADD11010BN35981 ===========================================================================           E R R O R   M E M O R Y   R E P O R T           -------------------------------------
Date:      10/13/11 19:58:34 ECU:       KOMBI39 JobStatus: OKAY Variant:   KOMBI39-------------------------------------------------------------
RESULT:    1 errors in error memory !-------------------------------------------------------------
140   Clamp R
Error frequency : 0
   Open circuit   Sporadic error =============================================================           E R R O R   M E M O R Y   R E P O R T           -------------------------------------
Date:      10/13/11 19:58:36 ECU:       LCM_II JobStatus: OKAY Variant:   LCM_II-------------------------------------------------------------
40    thermal sensor for oillevel defect
Error frequency : 14
   Error present =============================================================           E R R O R   M E M O R Y   R E P O R T           -------------------------------------
Date:      10/13/11 19:58:38 ECU:       ZKE3_GM1 JobStatus: OKAY Variant:   ZKE3_GM1-------------------------------------------------------------
RESULT:    2 errors in error memory !-------------------------------------------------------------
73    cable WI1 open circuit or wiper relay 1
Error frequency : 10
   Sporadic error-------------------------------------------------------------
75    cable WI2 open circuit or wiper relay 2
Error frequency : 9
Date:      10/13/11 19:58:38 ECU:       IHKA39 JobStatus: OKAY Variant:   IHKA39-------------------------------------------------------------
21    Auxiliary water pump
Error frequency : 255
   Short circuit to ground   Error present =============================================================           E R R O R   M E M O R Y   R E P O R T           -------------------------------------
Date:      10/13/11 19:59:13 ECU:       EWS3 JobStatus: OKAY Variant:   EWS3-------------------------------------------------------------
19    toleration of changing code increased with key # 1
Error frequency : 2
Date:      10/13/11 19:59:19 ECU:       ZAE2 JobStatus: OKAY Variant:   ZAE2-------------------------------------------------------------
24    digital seat occupation recognition
Error frequency : 124
   Remain over limiting value-------------------------------------------------------------
4     ignition circuit 0 -> driver airbag
Error frequency : 1
   Remain over limiting value =============================================================
http://paste.org/pastebin/view/39562
Było: M40b18 (e36), M52b20 (e39), M52TUB28 (e46)
Jest: M52TUB25 (e39 Touring)
PostNapisane: 13 października 2011, 18:21
Auxiliary water pump- pompka przy elektrozaworach do wymiany
digital seat occupation recognition- mata zajecia uszkodzona. Mozna przylutowac oporniczek lub zakodowac ncsem
thermal sensor for oillevel defect- czujnik poziomu oleju zepsuty- ten w misce
Reszte wklej sobie w google, te bledy kore wystepuja jeden lub kilka razy mozesz na razie zbagatelizowac.
PostNapisane: 13 października 2011, 18:43
Moje BMW: 520i e39
spotkałem się że co jakiś czas ten błąd się pojawia a nic się nie dzieje, tak samo jak
Kod:
itd.
PostNapisane: 13 października 2011, 18:55
czyli co ? dac spokoj tym bledom ? czy robic cos z tym ?
czy ta pompka to jest numer 1 na rysunku ?:
http://realoem.com/bmw/showparts.do?mod ... g=64&fg=18
Ostatnio edytowano 13 października 2011, 19:17 przez Bmwwe36, łącznie edytowano 1 raz
PostNapisane: 13 października 2011, 19:13
Pompa wody jest przydatna, pewnie przycisk rest na klimatroniku teraz Ci nie dziala. Kupisz ja na alle za 100zl. Czujnik poziomu oleju poinformuje Cie o tym ze jest za malo oleju (nie myl z czujnikiem cisnienia oleju), tyle ze chyba zaden zamiennik nie dziala poprawnie. Mata pasazera to najwazniejsza sprawa, zapewne swieci sie kontrolka poduszki, wiec w razie wypadku zadna poducha nie wystrzeli. Wystarczy przylutowac diode za 10gr lub zakodowac na kompie.
Sam sobie odpowiedz co musisz zrobic, to Twoje auto. Ja czujnik olalem bo silnik nie bierze mi oleju, jak bylby tanszy to pewnie bym sie skusil- w koncu warto miec sprawne auto.
PostNapisane: 13 października 2011, 19:24
Czy przy wymianie tego czujnika oleju trzeba spuszczać olej ? :P A tej pompki to gdzie szukac i pod jaka nazwa? I w ktorym miejscu jest w aucie
To jest to:
http://allegro.pl/bmw-5-e39-2-0-2-5-2-8 ... 18780.html
czy to:
http://allegro.pl/pompka-obiegowa-wody- ... 70460.html
PostNapisane: 14 października 2011, 06:55
Pompka to ten link
Czujnik jest na dole miski, wiec ja go wymontujesz to wszystko splynie. Raczej do zrobienia podczas wymiany oliwy, ale dla chcacego nic trudnego :P Tyle ze jak ostatnio patrzylem to w aso kosztowal 600 albo 700zl a na "najlepszy" zamiennik meyle ktos ostatnio na forum narzekal.
PostNapisane: 14 października 2011, 09:24
Moje BMW: 520i e39
jak lampka na liczniku od oleju nie świeci to nie ruszałbym tego czujnika w misce
w moim też się ten błąd pojawia (u kolegi też) a lampka się nie zaświeca - więc ok
PostNapisane: 14 października 2011, 18:56
Wlasnie przed chwila sprawdzilem, dziala ... nie mam pojecia o co chodzi. Swieci sie na zielono przy zgaszonym silniku i dmucha.
@edit
podlaczylem raz jeszcze, 2 nowe bledy:
Kod:
202   fuel trim limit Bank 1
Error frequency : 1 Logistic counter: 40
   Engine speed                               768.00  rpm   Engine temperature                          95.44  degrees C   oxygen sensor heater                        69.21  %   oxygen sensor voltage 1                      4.86  Volt
   Short circuit to batt+   emission related malfunction   defect code stored after filtering   Error present   Static error-------------------------------------------------------------
203   fuel trim limit Bank 2
   Engine speed                               768.00  rpm   Engine temperature                          95.44  degrees C   oxygen sensor heater                        69.21  %   oxygen sensor voltage 2                      4.86  Volt
   Short circuit to batt+   emission related malfunction   defect code stored after filtering   Error present   Static error =============================================================
Pomocy :D
PostNapisane: 16 października 2011, 21:10
Ponawiam :)
czy te błędy powyżej mają coś wspólnego z przepływomierzem ? Z innych tematów tam wynika że coś jest wspólnego. Jak jest naprawdę ?
Użytkownicy przeglądający ten dział: Brak zalogowanych użytkowników i 45 gości
