Teraz jest 25 października 2026, 05:08
 Tytuł: [E46] n42 problem cylindry nie działają
PostNapisane: 14 kwietnia 2021, 08:21
Moje BMW: E46 318i Turing
Kod silnika: N42
Witam wszystkich forumowiczów.
Posiadam E46 Touring 2002 N42 plus gaz.
Nie miałem błędów silnika i nagle zaczęła migać a później świecić check engine.
Oraz silnik zaczął nierówno pracować na chyba 3 cylindrach.
Sprawdziłem błędy i wyskoczył taki zestaw :szok: :
============1==============
1101 - mass Air Flow (MAF) Sensor Out of Self
============2==============
1100 -MAF Sensor Input Too High
============3==============
3321
============4==============
3315- ignition Coil Cylinder 31 High Input or None-Impedance
============5==============
1347 - Misfire Cylinder 3 With Fuel Cut-off; Misfire Cylinder 3
============6==============
3301- gnition Coil Cylinder 1 Contact Resistance or High-Impedance
============7==============
1345 - Misfire Cylinder 2 With Fuel Cut-off; Misfire Cylinder 2
============8==============
1343 - Misfire Cylinder 1 With Fuel Cut-off; Misfire Cylinder 1 with Fuel Cut-Off
============9==============
1341 -Multiple Cylinder Misfire With Fuel Cut-off;
============10==============
2824 - pressure Control Solenoid J Control Circuit/open
============11==============
2823 - pressure control solenoid
============12==============
2756 - torque Converter Clutch Pressure Control Solenoid
============13==============
2754 - Transmission Fluid Cooler Control Circuit Low
============14==============
2743 - transmission Fluid Temperature Sensor "B" Circuit High
============15==============
2753 - Transmission Fluid Cooler Control Circuit/Open
============16==============
2745 - Intermediate Shaft Speed Sensor "B" Circuit
============17==============
2742 - transmission Fluid Temperature Sensor "B" Circuit Low
============18==============
274E - Ogrzewanie sondy lambda przed kat
============19==============
P1347
OBDII: Fuel Level Sensor B Range / Performance
BMW: Misfire Cylinder 3 With Fuel Cut-off; Misfire Cylinder 3 with Fuel Cut-Off
============20==============
P1345
OBDII: SGC (Cam Position) Sensor Circuit Malfunction/ Crankshaft Position - Camshaft Position Correlation
BMW: Misfire Cylinder 2 With Fuel Cut-off; Misfire Cylinder 2 with Fuel Cut-Off
============21==============
P1343 - Misfire Cylinder 1 With Fuel Cut-off; Misfire Cylinder 1 with Fuel Cut-Off
============22==============
P1341
OBDII: Camshaft Position Sensor B Range / Performance
BMW: Multiple Cylinder Misfire With Fuel Cut-off; Multiple Cylinder Misfire with Fuel Cut-Off
Podejrzewam cewki ale czytałem na innych wątkach , że to nie to.
Uprzejmie proszę o radę.
 Tytuł: Re: [E46] n42 problem cylindry nie działają
PostNapisane: 27 kwietnia 2021, 19:32
Kod silnika: N42
Cześć ,
chciałbym podbić temat.
sprawdziłem dzisiaj siłownik valvetronic.
Po rozebraniu i sprawdzeniu podłączając do akumulatora siłownik działania poprawnie.
Co dziwne awaria zaczęła się od nierównej pracy silnika i Misfire na 3 cylindrach.
Po odłączeniu siłownika valvetronic silnik pracuje równo na wszystkich cylindrach ale nie na mocy i chleje benzynę jak tir.
Zauważyłem przy okazji że mam pękniętą kasetę plastikową rozrządu ale słyszałem że to norma i raczej nie przeszkadza w działaniu.
Świece były wymieniane
Proszę o sugestie.
PostNapisane: 28 kwietnia 2021, 17:14
Moje BMW: Vectra B
Kod silnika: X20XEV
Zmierz rezystancję między pinem w gnieździe silnika valvetronic, a jego obudową. Nie na zwarcie, a na rezystancję rzędu 200kOhm lub więcej.
Wartości rzędu 1k-200kOhm automatycznie dyskwalifikuje silnik. Ista podaje, że miernik nie może wykazywać żadnego przejścia
Problem z wypadaniem zapłonu na 3. cylindrze to też często problem z wałkiem valvetronic.
Auto nie ma mocy i pali sporo, ponieważ poza tym, że nie działa VVT, to jeszcze nie działają też Vanosy
PostNapisane: 3 maja 2021, 20:47
Kod silnika: N42
Dziękuję za odpowiedź.
Sprawdzę jak to działa i napiszę jaki wynik.
Vanosy były czyszczone ale możliwe że trzeba jeszcze raz.
Jeszcze dodam że łańcuch rozrządu ma duży luz.
Wydaje mi się to może być przyczyną.
Użytkownicy przeglądający ten dział: Google [Bot] i 111 gości
