Teraz jest 26 października 2026, 08:06
 Tytuł: [E87] jak skasować inspekcje w 120d
PostNapisane: 25 marca 2009, 17:37
mam problem ze skasowaniem inspekcji w 120d
Ostatnio edytowano 25 marca 2009, 19:18 przez krzys1001, łącznie edytowano 1 raz
 Tytuł: Kasowanie inspekcji w e87
PostNapisane: 22 kwietnia 2009, 19:34
:rotfl:
Sprobuj tego ponizej-ja mialem inspekcje plynu hamulcowego i podzialalo. ;)
Step 1
Insert key into slot
Step 2
Press start/stop button without depressing clutch/brake and wait for the service reminder to dissapear.
Step 3
Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4
You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5
When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6
You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
Sorry if this a re-post guys but like I said I couldn`t find it anywhere.
I accept no responsibility if you break your car, this is done at your own risk.
Użytkownicy przeglądający ten dział: Brak zalogowanych użytkowników i 97 gości
