Teraz jest 27 października 2026, 11:32
 Tytuł: [e46]328i blędy sond lambda
PostNapisane: 28 lipca 2010, 22:24
Moje BMW: E46 328i
Kod silnika: M52
Caly czas się borykam z takimi blędami ma ktoś pomysl co to może być ? wymiana sondy czy coś innego ?? dodam, że swiece są nowe, na cewkach przebicia niema...
Kod:
79    avtivate Lambda probe heating after KAT Bank 1
Error frequency : 1 Logistic counter: 40
   Engine speed                              2656.00  1/min   load                                       457.56  mg/Hub   lambda probe voltage after cat probe Ban     0.43  V   temperature cooling water                   96.75  Grad C   appear before (rel.)                       131.80  h
   Leitungsunterbrechung   CARB-Fehler   Fehler nach Entprellung gespeichert   Fehler momentan vorhanden   statischer Fehler
Errorcode: 4F 74 01 28 53 54 56 C1 C0 92-------------------------------------------------------------
216   Signal Lambda probe after-Kat Bank 2 not any Signal
Error frequency : 255 Logistic counter: 40
   Engine speed                              2112.00  1/min   load                                        70.81  mg/Hub   temperature cooling water                   97.50  Grad C   lambda probe voltage after cat probe Ban     0.42  V   appear before (rel.)                       131.50  h
   CARB-Fehler   Fehler nach Entprellung gespeichert   Fehler momentan nicht vorhanden   sporadischer Fehler
Errorcode: D8 B4 FF 28 42 0D C2 53 C0 95-------------------------------------------------------------
215   Signal Lambda probe after-Kat Bank 1 not any Signal
Error frequency : 190 Logistic counter: 39
   Engine speed                              1024.00  1/min   load                                        70.81  mg/Hub   temperature cooling water                   96.75  Grad C   lambda probe voltage after cat probe Ban     0.40  V   appear before (rel.)                       131.10  h
Errorcode: D7 B4 BE 27 20 0D C1 50 C0 99
221   LS voltage NKAT sensor 2, sensor to slow
Error frequency : 14 Logistic counter: 37
   Engine speed                              3040.00  1/min   load                                        76.26  mg/Hub   temperature cooling water                   92.25  Grad C   lambda probe voltage after cat probe Ban     0.35  V   appear before (rel.)                       128.30  h
Errorcode: DD B8 0E 25 5F 0E BB 45 C0 B5-------------------------------------------------------------
227   lambda contol tolerance Bank 1 to big
Error frequency : 8 Logistic counter: 39
   Engine speed                               896.00  1/min   load                                        70.81  mg/Hub   temperature cooling water                   97.50  Grad C   lambda contol tolerance Bank 1             -19.92  %   appear before (rel.)                       101.90  h
   Abweichung mager   CARB-Fehler   Fehler nach Entprellung gespeichert   Fehler momentan nicht vorhanden   sporadischer Fehler
Errorcode: E3 B2 08 27 1C 0D C2 4D C1 BD-------------------------------------------------------------
159   Signal Lambda probe after-Kat Bank 2 max value over limit
Error frequency : 17 Logistic counter: 39
   Engine speed                              2208.00  1/min   load                                       364.96  mg/Hub   temperature cooling water                   64.50  Grad C   lambda probe voltage after cat probe Ban     1.23  V   appear before (rel.)                       100.20  h
   Kurzschluss gegen U-Batt.   CARB-Fehler   Fehler nach Entprellung gespeichert   Fehler momentan nicht vorhanden   sporadischer Fehler
Errorcode: 9F B1 11 27 45 43 96 F5 C1 CE
Moje e30, magnes na laski
 Tytuł: Re: [e46]328i blędy sond lambda
PostNapisane: 25 sierpnia 2010, 12:19
Moje BMW: E46 328i
Kod silnika: M52
Kolego bardzo mi przykro ale na 99% sonda Ci padła a nawet może 2 szt.
Jedz do kogoś na kompa i niech podepnie się tak żeby widzieć prace wszystkich 4 sond. Jak odpalisz auto i po 2-3 minutach jeszcze któraś bedzie miała takie same wartości w mA to jest szmelc.
ori w serwisie 800 szt... allegro używka 100...
Pozdro
Moje E46 328i http://www.bmw-sport.pl/viewtopic.php?t ... bfc6f137f0
