Teraz jest 12 listopada 2026, 16:48
Utwórz nowy temat Odpowiedz w temacie  [ Posty: 115 ]  Przejdź na stronę Poprzednia strona  1, 2, 3, 4, 5, 6  Następna strona
 Tytuł: Re: [E46] Coupe Felgi 19 ET 35 8,5 JJ Czy wejdą?
PostNapisane: 7 marca 2010, 16:54
Moje BMW: E46 328i
Kod silnika: M52
właśnie o to mi chodzi aby trochę wystawało ale nieobcierało oponę z naciągiem...
Moje e30, magnes na laski
PostNapisane: 11 marca 2010, 15:04
Moje BMW: 325 ///M5
Kod silnika: M54B25 ///S38B38
Vermilion napisał(a):
Dlatego test na certyfikat JWL (prawdziwy certyfikat, a nie znaczek wybity na feldze) sklada sie z 3 czesci, ktore masz opisane tutaj
Cornering Fatigue Test (Drum Endurance Test)
The purpose of this test is for checking wheel rim strength and durability. Place a wheel assembly with tire on test equipment. Radial stress is then added to simulate vehicle weight.
Test run 500,000 cycles
After 500,000 cycles inspect for cracks, deformation and any nut loosening.
Radial Load Fatigue Test (Rotary Bending Test)
JWL pass criteria: 100,000 cycles
The purpose of this test is for checking durability of the wheel disc. The spokes and the hub are the first point of weight distribution from the vehicle and spoke strength is gauged by this test.
Place a wheel on testing equipment and by adding bending stress to center of disc –
Test run 100,000 cycles
After 100,000 cycles, inspect for cracks, deformation and any nut loosening.
13 Degree Impact Test
JWL pass criteria: 594 kg
The main purpose of test is for checking strength between rim and disc cross section. The “joint” or the area where the spoke and the rim meet is an important structural area that is subject to great stress. The horizontal weight of the rim and the vertical stress of the spokes meet at this joint and proper structural stability is crucial for a proper wheel.
The wheel assembly is placed with tire tilted 13 degrees from horizontal plane on testing equipment.
A preset weight is dropped on the outer sidewall of tire, thus giving impact to the wheel/tire. Then inspect for cracks, deformation and air leak.
This test is very important for the recent trend of a larger/wider wheel with lower profile tire combination, because there is less air volume than OE wheel/tire and more stress to inner rim section. This test simulates actual usage condition such as hitting corner curb or objects from side.
Jezeli jest taka potrzeba to moge powyzszy opis przetlumaczyc. Kazda z naszych felg przechodzi te testy, niedlugo postaramy sie wrzucic na strone filmy z tego jak sie podczas nich zachowuja. Oprocz tego felgi sa przeswietlane i a wycinki badane pod mikroskopem. Gdyby Unia zdecydowala sie w koncu na wlasny certyfikat/homologacje felg aluminiowych, to 99% chinskich felg musialoby zniknac z rynku (ale tego nie zrobia, bo to samo dotyczyloby wloskich).
Możesz rozwinąć o co chodzi z tym znaczkiem JWL - od dawna zastanawiałem się co to oznacza, a nikt nie potrafił tego wiarygodnie wytłumaczyć.
I przetłumacz jak bedziesz miał chwilę ten angielski tekst.
Dzięki!
PostNapisane: 11 marca 2010, 15:06
Moje BMW: 325 ///M5
ppatryk napisał(a):
ale ten z bmw też jest lipny
ja używam taki porządny który na pewno się nie połamie heheheh
Chyba niezły "Pudzian" z Ciebie kolego jak potrafisz złamać oryginalny klucz od odkręcania kół BMW - który uchodzi za nizniszczalny :rotfl:
PostNapisane: 11 marca 2010, 17:33
Dzięki!
JWL pochodzi od JAPAN LIGHT ALLOY WHEEL i ten certyfikat jest wystawiany przez ta organizacje, monitorujaca japonski rynek felg i opon http://www.jawa.jp/ , firmy, ktore sa tam wymienione posiadaja taki certyfikat na swoje produkty i moga sie poslugiwac logiem JWL.
Podobnie jest z certyfikatem VIA, wystawianym przez http://www.jwtc.jp/open/html/e/index.html
Pozniej przetlumacze szczegoly testow.
PostNapisane: 3 kwietnia 2010, 23:04
Garaż: http://www.bmw-sport.pl/viewtopic.php?f=6&t=79102
Nie chcę zakładać dodatkowego tematu, wiec podłączę się z moim pytaniem:
Czy będą pasowały do e46 - zawias m-tech felgi:
BMW star spoke 230
PRZÓD 8JX19H2 ET 37 NR KATALOGOWY 6774724
TYŁ 9JX19H2 ET 37 (ET 39) NR KATALOGOWY 6774725
lub
ASA AR1
PRZÓD 8,5JX19H2 ET37
TYŁ 9,5JX19H2 ET36
bo co do tych drugich to nie jestem pewien, a i jakie oponki najlepiej 225/35 i 255/30 czy inne?
E46 330Ci CABRIO
PostNapisane: 23 lipca 2010, 19:49
koledzy jaki to jest model felg bo po rozkodowaniu vinu takie mialem
LT/ALY WHEELS STAR SPOKE 45
320 Coupe
PostNapisane: 24 lipca 2010, 11:22
Taki
PostNapisane: 31 lipca 2010, 00:06
dziekuje Ci bardzo;d
320 Coupe
PostNapisane: 27 sierpnia 2010, 12:20
Moje BMW: E93
koledzy mam pytanie jaki rozmiar felg do e46 stalowki 16"(zima)
ponoc 330d ma inaczej niz inne silniki czy to prawda?
pozdrawiam
PostNapisane: 27 sierpnia 2010, 12:24
Moje BMW: E36 & E46
Kod silnika: M42 & M52
acer3000, szukanie nie boli...
do 330d min. 17" wchodzą... wystarczy poszukać :zabawa:
PostNapisane: 17 listopada 2010, 23:20
Moje BMW: E46 Cabrio
Kod silnika: M54B22
a ja mam pytanko: czy jest szansa, żeby felga z E46 M3 - 19" 9,5" ET27 weszła na tył do zwykłej coupe?
zawieszenie gwintowane...
byłe E36 Cabrio
byłe E46 Coupe
PostNapisane: 18 listopada 2010, 11:47
Bez przerabiania tylnych nadkoli, beda sprawialy problemy.
PostNapisane: 12 grudnia 2010, 17:39
Moje BMW: m3 e46
Kod silnika: s54b32
Panowie to i ja mam pytanie..
na zime mam wsadzone ori fele m-pakietowe Styling 68 , et na felgach jak z m3 przod 47, tyl 25...wszystko ladnie chodzi i nie obciera, auto w ori m-pakiecie /zawias tez oczywiscie/..i teraz pytanie..skoro zimowki podejda to czy fele od m3 tez beda pasowac??
latem mialem 18 et35 opona tyl 255 zawias na gwincie /nisko/ i przy mocnym dobijamiu lekko obcieralo..
jak dla mnie auto ma zagiete ranty i lekko wyciagniete nadkola..
wracajac do pytania czy fele z m3 podejda??
PostNapisane: 12 grudnia 2010, 17:50
Moje BMW: M3 e46
Kod silnika: S54
Nie powinny, chyba że:
A jakie szerokości mają te felgi?
PostNapisane: 12 grudnia 2010, 17:59
Moje BMW: m3 e46
Kod silnika: s54b32
7,5x17'....
http://felgenkatalog.auto-treff.com/680.htm
pelne dane w tabeli
PostNapisane: 12 grudnia 2010, 19:45
Moje BMW: M3 e46
Kod silnika: S54
premier, pytałem o twoje felgi.
Ta tabela jest błędna nie było do M3 e46 17tek o różnych szerokościach.
PostNapisane: 12 grudnia 2010, 21:04
Moje BMW: m3 e46
Kod silnika: s54b32
jak sprawdzalem przed zalozeniem to bylo jak z tej tabeli, dlatego dalem link
przod 7,5x17 * vorne 225/45R17 ET 47
tyl 7,5x17 * hinten 225/45R17 ET 25
PostNapisane: 12 grudnia 2010, 22:01
Moje BMW: M3 e46
Kod silnika: S54
Rozumiem że chcesz założyć letnie 18tki od M3 e46? O takie:
Nie wiem czy wiesz co to jest ET. ET to wymiar d na tym rysunku:
Mimo że Felgi o których mowa mają takie same ET to 18tki od M3 są o 0,5 cala szersze z przodu i 1,5 z tyłu. Przez co felga z przodu wypełni nadkole o 6mm bardziej zarówno do zewnątrz jak i do wewnątrz.
Natomiast tylna o 19mm w każdą stronę.
PostNapisane: 16 grudnia 2010, 13:46
Moje BMW: m3 e46
Kod silnika: s54b32
ogolnie zawsze bylem przekonany ze max et do e46 to 34 a tu nagle wsadzam 25...
a zastanawiam sie nad felgami
http://allegro.pl/felgi-aluminiowe-19-8 ... 71410.html et 35 na tyl
lub
http://allegro.pl/felgi-aluminiowe-19-8 ... 71677.html et 27 ... ale czy to bedzie wszystko pasowac....
podejzewam ze skoro et35 z opona 255 na taborecie lekko obciera przy mocnym dobiciu to do et 27 bede musial opone 235 wsadzic..jak uwazacie
PostNapisane: 17 grudnia 2010, 17:22
Kod silnika: M52
Witam!
Pozwolcie ze zapytam. Aktualnie moja bunia ma zalozone styling 135 M-Doppelspeiche. Na wszystkich czterek sztukach oponki 225/40/18. Niestety jedna felga jest peknieta-odradzono mi spawanie. Postanowilem kupic ori uzywke w dobrym stanie.
Do BMW nie sprzedajemy kompletow takiej samej szerokosci
I tu moje pytanko, czy jak dokupie taka samo felge to bedzie wszystko ok czy lepiej 2 szersze na tylnia os? Jakie to ma znaczenie? Z gory dzieki za odp. Pozdrawiam
WE SHALL KNOW NO FEAR
