Teraz jest 24 października 2026, 03:49
 Tytuł: problem z instalacja gry
PostNapisane: 19 marca 2012, 15:23
Witam może tu ktoś mi podpowie po instalacji gry doom 3
i próbie uruchomieniu wyskakuje taka tabelka z tymi danymi
o co chodzi ?? nie jestem specjalista od kompów :/
DOOM 1.0.1282 win-x86 Sep 16 2004 16:45:51
1808 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2
1280 MB System Memory
256 MB Video Memory
Winsock Initialized
Hostname: arek-b8bba1ef33
IP: 192.168.1.10
doom using MMX & SSE & SSE2 for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded pk4 C:\Gry\Doom 3\base\game00.pk4 with checksum 0x7dafc4d4
Loaded pk4 C:\Gry\Doom 3\base\pak000.pk4 with checksum 0x28d208f1
Loaded pk4 C:\Gry\Doom 3\base\pak001.pk4 with checksum 0x40244be0
Loaded pk4 C:\Gry\Doom 3\base\pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 C:\Gry\Doom 3\base\pak003.pk4 with checksum 0xcd79d028
Loaded pk4 C:\Gry\Doom 3\base\pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 C:\Gry\Doom 3\base\pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 C:\Gry\Doom 3\base\zpak001.pk4 with checksum 0x441b6af2
Current search path:
C:\Gry\Doom 3/base
C:\Gry\Doom 3\base\zpak001.pk4 (1448 files)
C:\Gry\Doom 3\base\pak005.pk4 (63 files)
C:\Gry\Doom 3\base\pak004.pk4 (5137 files)
C:\Gry\Doom 3\base\pak003.pk4 (4676 files)
C:\Gry\Doom 3\base\pak002.pk4 (6120 files)
C:\Gry\Doom 3\base\pak001.pk4 (8972 files)
C:\Gry\Doom 3\base\pak000.pk4 (2698 files)
C:\Gry\Doom 3\base\game00.pk4 (2 files)
game DLL: 0x0 in pak: 0x0
file system initialized.
----- Initializing Decls -----
------- Initializing renderSystem --------
using ARB renderSystem
renderSystem initialized.
5151 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
execing DoomConfig.cfg
couldn't exec autoexec.cfg
5151 strings read from strings/polish.lang
----- Initializing Sound System ------
sound system initialized.
----- R_InitOpenGL -----
Initializing OpenGL subsystem
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
Couldn't find proc address for: wglGetExtensionsStringARB
Couldn't find proc address for: wglSwapIntervalEXT
Couldn't find proc address for: wglGetPixelFormatAttribivARB
Couldn't find proc address for: wglGetPixelFormatAttribfvARB
Couldn't find proc address for: wglChoosePixelFormatARB
Couldn't find proc address for: wglCreatePbufferARB
Couldn't find proc address for: wglGetPbufferDCARB
Couldn't find proc address for: wglReleasePbufferDCARB
Couldn't find proc address for: wglDestroyPbufferARB
Couldn't find proc address for: wglQueryPbufferARB
Couldn't find proc address for: wglBindTexImageARB
Couldn't find proc address for: wglReleaseTexImageARB
Couldn't find proc address for: wglSetPbufferAttribARB
...calling CDS: ok
...created window @ 0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...PIXELFORMAT 7 selected
...creating GL context: succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
sound: STEREO
X..GL_ARB_multitexture not found
X..GL_ARB_texture_env_combine not found
X..GL_ARB_texture_cube_map not found
X..GL_ARB_texture_env_dot3 not found
X..GL_ARB_texture_env_add not found
X..GL_ARB_texture_non_power_of_two not found
X..GL_ARB_texture_compression not found
X..GL_EXT_texture_filter_anisotropic not found
X..GL_EXT_texture_lod not found
X..GL_1.4_texture_lod_bias not found
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: Aktualna kombinacja karty grafiki / sterownika nie obsługuje niezbędnych opcji.
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
 Tytuł: Re: problem z instalacja gry
PostNapisane: 19 marca 2012, 15:39
Moje BMW: 535d++
Kod silnika: N57S
dirextX, stabilne sterowniki do płyty i karty zainstalowane?
PostNapisane: 19 marca 2012, 15:52
Podaj parametry kompa
PostNapisane: 19 marca 2012, 15:54
Moje BMW: Mitsubishi Galant
Kod silnika: 4G63
wiem że gra ma ograniczenia co do niektórych kart, po prostu ich nie obsługuję, może tu leży pies pogrzebany ? Warto sprawdzić.
PostNapisane: 19 marca 2012, 16:38
dirextX zainstalowany był na płycie, płyta oryginalna
Mój komp
AMD Athlom 64 Processor 2800 +
1.8GHZ 1.25GBRAM
karta grafiki geforce FX 5500 256MB
może trzeba ściagnac jakies najnowsze sterowniki do karty graficznej ?
PostNapisane: 19 marca 2012, 18:05
Moje BMW: e34
Kod silnika: M50B25
Pobierz, to nic nie kosztuje i trwa parę minut. A ten Doom to ori? Być może trafiłeś na trafną wersję, sprawdzałeś na innym kompie?
PostNapisane: 19 marca 2012, 22:14
Moje BMW: e39 530D
Kod silnika: m57d30
Wydaje mi się, że Doom III nie lata na geforce 5XXX. Ale sprawdź trop nie obsługiwanych grafik.
Doom III :hurra: ... stare dobre czasy. :oczami:
PostNapisane: 19 marca 2012, 23:14
może
w exe ustawienia gry powyłączaj wszystkie bufory, cienie, eaxy itp, wybierz standardowy sterownik dzwięku
jak masz vstę lub nowszy system to uruchom exe gry ustawiając zgodność z xp
tego nie polecam ale jak masz sterownik ati catalyst to zamień na ati omega
można też spróbować podrzucić kraka
zainstaluj powtórnie
PostNapisane: 20 marca 2012, 15:09
ściągnąłem sterowniki, ale ciągle to samo
zainstalowałem gre jeszcze raz i to samo
no nic jeszcze moze cos popróbuje, szkodaq bo w dooma 3 nigdy nie grałem a podobno jest świetny
PostNapisane: 20 marca 2012, 15:15
Kod silnika: 4G63
sprawdź czy twoja karta obsługuje grę, jeśli nie to masz przyczynę.
PostNapisane: 20 marca 2012, 21:24
Moje BMW: e39 530D
Kod silnika: m57d30
Wg readme.txt twoja grafika jest OK.
Biorąc pod uwagę co już sprawdziłeś, to dodatkowo zmień (o ile używasz) witaminę, dodaj do zaufanych w antywirusie, w przypadku visty i 7 uruchom w trybie zgodności z xp.
Poszukaj jakieś iso w sieci i zainstaluj od nowa. Może jest problem z obecną instalką?
PostNapisane: 21 marca 2012, 07:45
to już nie smoka epoka hehe, masz w problemie napisane że nie znajduje ścieżek do grafiki i dźwięku, jak nie krakiem i z zgodnością xp to z dosboxa http://porady-komputerowe.blogspot.com/ ... ukcja.html
PostNapisane: 9 września 2012, 17:17
Moje BMW: E36 320i Coupe
Kod silnika: M50B20
A GF FX5500 nie miało przypadkiem 128mb pamięci? Sam kiedyś miałem taką i coś mi świta, że to jednak 128 było :P
PostNapisane: 9 września 2012, 20:48
Moje BMW: E60 525d
Garaż: E60 525d M57 http://www.bmw-sport.pl/viewtopic.php?f=6&t=135186
E30 318 Cabrio
Było: E46 318i N42B20
Ooo coś nowego, chyba chodzi raczej o directX ;)
Ati to radeony, mówimy tutaj o nvidia gf fx5500
Teoretycznie gra powinna działać na tej karcie. Problem jaki tutaj wkleiłeś nie mówi bezpośrednio o problemie z directX a z opengl'em. opengl32 jest zaladowany poprawnie, ale nie znalezione są rozszerzenia których wymaga silnik graficzny gry.
Możemy z tym powalczyć ale potrzebuje więcej informacji, na początek model płyty głównej...
E60 525d 177ps 400Nm ----> 233ps 524Nm by TCPerformance
PostNapisane: 10 września 2012, 06:08
omegi są i dla invidi więc każdy pod cechy swojego kompa, może napisałem intuicyjnie bo nigdy nie kupie invidi
