Teraz jest 16 sierpnia 2026, 06:10
 Tytuł: [Exx] powerbass s-12 + signat rom 4 ?
PostNapisane: 23 kwietnia 2011, 14:19
Moje BMW: e36 coupe
Kod silnika: m42b18
Pytanie do ludzi siedzacych w CA
Posiadam PB s-12
Power Handling
(RMS/Peak): 300/600 watts
Nominal Impedance:
Single 4-ohm
Voice Coil Size: 2 in
Frequency Response:
31Hz - 450Hz
Sensitivity: 91dB
Motor Structure: 142 oz
Mounting Depth: 5.5 in
Oraz moge miec po taniosci wzmacniacz Signat ROM 4
Ciezko o nim znalezc informacje ale udalo mi sie wygrzebac takie cos
Amplificateur 4 canaux
Puissance : 4x90 (4 ohm, THD = 0.05%)
Puissance : 2x240 (4 ohm, ponté, THD = 0.1%)
Bande passante : 10Hz - 60KHz
Filtre passe-bas : 50-250Hz, 12dB/octave
Filtre passe-haut : 50-250Hz, 12dB/octave
Dimensions : 230 x 60 x 390
Specification data:
Amp type: 4 channel
Pc board: double sided
Power terminal: gold plated screw type
Speaker terminals: gold plated screw type
Signal input terminals: 4 x RCA jacks gold plated
BIC balanced input circuity
ENS Electronic Noise Suppression
Bridged mode: yes (min. 4 Ohm)
Trimode operation: built in
Protection and control circuites: Temperature, overload, short circuit,
DC offset
Output load impendance (stereo mode): 2 - 8 Ohm
Active low pass filter: 50-250Hz, 12dB (ch 1/2 & 3/4)
Active high pass filter: 50-250Hz,12dB (ch 1/2 & 3/4)
Technical data:
Max. peak music power: 600W
RMS power at 4 Ohm (0,05% THD): 4x90W
RMS power at 4 Ohm (0,1% THD): 2x240W
RMS power at 2 Ohm (0,2% THD): 4x125W
S/N ratio (A-weighted): 105 dB
Freq. response (-3dB): 10-60 kHz
Stereo separation: 70 dB
Input sensitivity: 150mV - 5V
Input impendance: 25 kOhm
Fuse rate: 2 x 30A
Supply voltage: 12 V DC
Dimensions: 242 x 60 x 390 mm
Czy bedzie to dobre polaczenie, czy moze PB wogole na tym nie zagra?
Czy dalo by rade np zmostkowac dwa kanaly i dac pod suba a kolejne dwa by zasiliy przod?
 Tytuł: Re: powerbass s-12 + signat rom 4 ?
PostNapisane: 23 kwietnia 2011, 15:54
ta :wstyd: zasilisz przód drzwi (zestaw odseparowany), tylne glośniki, 2xskrzynie w bagażniku i zostanie na jakiegoś woofera pod siedzenie,i w 100% nie wykorzystasz tego wzmacniacza.
To nie wzmacniacz to szatanista :wstyd:
 Tytuł: Re: [Exx] powerbass s-12 + signat rom 4 ?
PostNapisane: 23 kwietnia 2011, 19:18
Moje BMW: E46Coupe
Garaż: /E46Turbo
320Cd @ 2.5 M50Turbo.
Ramzess, hmm do czego sie doczepiłeś? :zdziwko:
Hrynio napisał(a):
RMS power at 4 Ohm (0,05% THD): 4x90W RMS power at 4 Ohm (0,1% THD): 2x240W RMS power at 2 Ohm (0,2% THD): 4x125W
Hrynio napisał(a):
Puissance : 4x90 (4 ohm, THD = 0.05%) Puissance : 2x240 (4 ohm, ponté, THD = 0.1%)
Nie widze najmniejszego problemu w podłączeniu suba + przodu do tego wzmaka. Ale czy on zagra pod 240W RMS (i czy wzmak tyle wyciągnie ) niestety nie wiem. Niby powinien dostać ~300rms
PostNapisane: 24 kwietnia 2011, 02:07
Pod tym subem zagra ale tak jak kolega wyżej wspomniał troszkę więcej mocy mógłby dostać.
PostNapisane: 25 kwietnia 2011, 23:36
Kod silnika: 2jz
jeśli tam jest zdrowe 240w to zagra bo daja pod niego czesto około 250w
sam mam s12 bs ale napedza go rockford 300s jakoś to już gra nie schodzi szalenie nisko ale dość punktualny
PROGRAMOWANIE KODOWANIE DIAGNOSTYKA CHIP TUNING/ TUNING MECHANICZNY - WLKP, DOLNY ŚLĄSK
PostNapisane: 26 kwietnia 2011, 10:12
Hrynio skoro możesz mieć ten wzmacniacz po taniości jak sam napisałeś, to go weź a jeśli będzie Ci mało czy będziesz czuł niedosyt to sobie go wymienisz na coś mocniejszego :)
