Teraz jest 11 listopada 2026, 14:41
 Tytuł: [Exx] prosba o przetlumaczenie programu NCS Expert
PostNapisane: 22 stycznia 2010, 13:39
witam mogl bym mi ktos przetlumaczyc te funkcje
AUSSENTEMP_WARNUNG_GONG : External Low Temp Warning Gong
AUT_SITZVERSTELLUNG : Automatic Seat Adjustment (select when unlocked or when driver door opened) linked to key number
AUTO_ZV_DISABLE : disable automatic central locking
BC_KL_R : Interior lighting ON when ignition is switched off after driving with headlights on
DWA-QUITTIERUNG : Anti Theft System Acknowledgement
EINSCHALTMELDUNG_IMMER : Power-up messgage always
ERKENNUNG_SITZBELEGUNG_1 : Recognition seat allocation (don't switch this off otherwise the airbag system gets up-set)
FH_BEIFAHRERTUER_TIPP_AUF : power window Passenger Door Window Down one touch
FH_BEIFAHRERTUER_TIPP_ZU : power window Passenger Door Window Up one touch
FH_FAHRERTUER_TIPP_AUF : power window Driver Door Window Down one touch
FH_FAHRERTUER_TIPP_ZU : power window Driver Door Window Up one touch
FH_TUEREN_HINTEN_TIPP_AUF : doors in rear Window Down one touch
FH_TUEREN_HINTEN_TIPP_ZU : doors in rear Window Up one touch
Fußraumklappen: Floor flaps (IHKA)
HBA_DSC_5_7 :
HECKKLAPPE_ENTSICHERN : Rear Trunk opening from remote key
HEIMLEUCHTEN : Home Shine (Follow me home lights)
INNENLICHT_AN_MEHRFACH_ZV : Interior Light On Several Times central locking
KEY_MEMORY_IHK : Key Memory IHK Module (A/C temperature memory from key number)
KEY_MEMORY_RADIO : Key Memory Radio (Radio channel / volume from key number)
KOMFORTOEFFNUNG : Comfort Opening
KOMFORTOEFFNUNG_FB : Comfort Opening remote key
KOMFORTSCHLIESSUNG : Comfort Closing
KOMFORTSCHLIESSUNG_FB : Comfort Closing remote key
LAUTSTAERKE_HINTEN : Volume in the Back
NOTSTROMSIRENE : Emergency Power Siren
QUIT_OPT_ENTSCH : optical Acknowledge remote un-locking (two flashes)
QUIT_OPT_SCHAERF : optical Acknowledge remote locking (one flash)
SCHIEBEHEBEDACH_TIPP_AUF : One touch sun-roof open
SCHIEBEHEBEDACH_TIPP_ZU : One touch sun-roof close
SOFT ON/OFF : Soft dim/undim of the interior lights
SPRACHE : Language selection
TAGFAHRLICHT_ECE : Daylight Headlights
TEMPERATUR_EINHEIT : Temperature Unit (C/F)
UMLUFT MEMORY : Circulating Air Flap Memory (remembers if re-circ is on after shutdown)
VERBRAUCH D1 : Consumption units
VERRIEGELN_AUT_AB_X_KMH : Automatic central locking after X KMH
VERRIEGELN_AUT_MACH_2_MIN : Automatic central locking after 2 MIN
VERRIEGELUNGSSCHWELLE : locking Device-swells (threshold) (speed of X above)
WEG_EINHEIT : Distance unit (distance, miles or km)
ZEIT_EINHEIT : Time unit (12H or 24H)
ZUENDSCHLUESSEL_WARNUNG : Ignition key Warning, a really anoying option which beeps if you leave the key in the ignition
ZV_SELEKTIV : central locking selectively (selective unlocking)
Each individual key can also be set to allow selective un-locking and automatic locking after X MPH.
Gdyby Bóg popierał przedni napęd to chodzilibyśmy na rękach!!!
 Tytuł: Re: prosba o przetlumaczenie programu NCS Expert
PostNapisane: 23 stycznia 2010, 11:04
pomoze mi ktos z tym programem bo chcialem sie troche pobawic z moja bunia. :)
PostNapisane: 23 stycznia 2010, 11:19
Moje BMW: E39 TURING
Kod silnika: M57 dA
prościej będzie jeśli poćwiczysz angielski!!!! albo idź do tłumacza to ci przetłumaczy. lub kup translator.
PostNapisane: 23 stycznia 2010, 11:39
Moje BMW: E90 LIM
Kod silnika: M47N2
chudy4790, chudy4790, kolego wystarczy jakikolwiek translator bo w miare proste, ale zeby nie bylo :P
External Low Temp Warning Gong - sygnal "gong" gdy temp zewnetrzna spadnie ponizej 3 stopni
Automatic Seat Adjustment (select when unlocked or when driver door opened) linked to key number - automatyczne ustawienie pozycji fotela gdy otworzysz zamek drzwi lub dzrzwi kierowcy, ustawienia przypisane do pamieci kluczyka
disable automatic central locking - wylaczenie automatycznego zamykania/blokowania drzwi po ruszeniu
Interior lighting ON when ignition is switched off after driving with headlights on - wewnetrzne oswietlenie wlacza sie gdy wylaczysz zaplon po jezdzie na swiatlach
Anti Theft System Acknowledgement - uaktywnienie systemu antynapadowego
Power-up messgage always - informacja o wlaczeniu zasilania??
Recognition seat allocation (don't switch this off otherwise the airbag system gets up-set) - nie wiem :(
power window Passenger Door Window Down one touch - szyba pasazera opuszcza sie po jednym przycisnieciu przycisku
power window Passenger Door Window Up one touch - szyba pasazera podnosi sie po jednym przycisnieciu przycisku
power window Driver Door Window Down one touch - szyba kierowcy opuszcza sie po jednym przycisnieciu przycisku
power window Driver Door Window Up one touch - szyba kierowcy podnosi sie po jednym przycisnieciu przycisku
doors in rear Window Down one touch -tylne szyby opuszczaja sie po jednym przycisnieciu przycisku
doors in rear Window Up one touch - tylne szyby podnosza sie po jednym przycisnieciu przycisku
Rear Trunk opening from remote key - bagaznik otwiera sie z pilota
Home Shine (Follow me home lights) - doswietlanie drogi do domu [na wylaczonym zaplonie migasz "slugimi" i swiatla swieca przez ok 30 sek]
Interior Light On Several Times central locking - wewnetrzne swiatla wlaczaja sie podczas zamykania/otwierania drzwi
Key Memory IHK Module (A/C temperature memory from key number) - ustawienie klimatyzacji wg pamieci danego kluczyka
Key Memory Radio (Radio channel / volume from key number) - ustawienie radia wg pamieci z kluczyka
Comfort Opening - komfortowe otwieranie
Comfort Opening remote key - komfortowe otwieranie z pilota
Comfort Closing - komfortowe zamykanie
Comfort Closing remote key - komfortowe zamykanie z pilota
Volume in the Back - ustawienie fader w radiu na tyl
Emergency Power Siren - syrena awaryjnego zasilania ??? nie wiem
optical Acknowledge remote un-locking (two flashes) - kierunki mrugaja dwa razy po otwarciu z pilota
optical Acknowledge remote locking (one flash) - kierunki mrugaja raz po zamknieciu z pilota
One touch sun-roof open - jedno przycisniecie i szyberdach sie otwiera
One touch sun-roof close - jedno przycisniecie i szyberdach sie zamyka
Soft dim/undim of the interior lights - programowe zsciemnianie/rozjasnianie wewnetrznego oswietlenia
Language selection - wybor jezyka
Daylight Headlights - swiatla dzienne [chyba po odpaleniu auta]
Temperature Unit (C/F) - jednostki temp
Circulating Air Flap Memory (remembers if re-circ is on after shutdown) - pamiec ustawien klimatyzacji
Consumption units - jednostki spalania
Automatic central locking after X KMH - automatyczne zamkniecie drzwi po przekroczeniu X predkoscki
Automatic central locking after 2 MIN - automatyczne zamkniecie drzwi po 2 minutach
locking Device-swells (threshold) (speed of X above) - blokada urzadzen po przekorczeniu predkosci X [nie jestem pewien]
Distance unit (distance, miles or km) - jednoski odleglosci
Time unit (12H or 24H) - jednoski czasu
Ignition key Warning, a really anoying option which beeps if you leave the key in the ignition - przypomnienie o zostawieniu kluczyka w stacyjce, komputer bedzie pikal
central locking selectively (selective unlocking) - selektywne otwieranie/zamykanie zamka
to by bylo na tyla, jesli ktos zauwazy jakies bledy niech poprawi, bo robilem na szybko :cwaniak:
Pomoc z ICOM, ISTA+, ISTA P, Esys, NCS Expert, polskie menu, mapy nawigacji, kodowanie opcji, zmiana USA na EU, dorabianie kluczyków seria Exx oraz Fxx itp ;)
PostNapisane: 23 stycznia 2010, 12:12
dzięki kolego za pomoc zaraz idę się troszkę pobawić z autkiem :) a idzie zrobić żeby swiatła same się zapalały po odpaleniu???
PostNapisane: 23 stycznia 2010, 13:46
Moje BMW: e39 530d
tak, funkcja TAGFAHRLICHT_ECE : Daylight Headlights
Kupię deskę w skórze.
PostNapisane: 23 stycznia 2010, 17:00
a jeszcze mam pytanie jak zaprogramowalem sobie zeby po ruszeniu drzwi sie zamykaly to cos takieo ze jak zgasze silnik zeby same sie otwaly anie po nacisnieciu guzika???
PostNapisane: 23 stycznia 2010, 17:13
Moje BMW: E90 LIM
Kod silnika: M47N2
chudy4790, czy Ty masz jakies problemy z czytaniem :rotfl:
to:
lub
PostNapisane: 23 stycznia 2010, 17:16
zle mnie zrozumiales zrobilem sobie zeby sie po 5km/h zamkly i chodzi mi oto czy moga sie same otworzyc bo zgaszeniu silnika.
PostNapisane: 23 stycznia 2010, 17:20
Moje BMW: E90 LIM
Kod silnika: M47N2
chudy4790, aha no to sorki :zawstydzony: a taka funkcje spelnia chyba
o ile sie nie myle to tak powinien dzialac ten system, ale moge sie mylic
PostNapisane: 23 stycznia 2010, 17:40
Anti Theft System Acknowledgement - uaktywnienie systemu antynapadowego mam to aktywowane i tak sie niechce otwierac:(
PostNapisane: 23 stycznia 2010, 18:08
Moje BMW: E90 LIM
Kod silnika: M47N2
a moze w tym da sie cos ustawic, nie wiem bo niestety nie mam jak sprawdzic
PostNapisane: 29 stycznia 2010, 15:02
wracam do mojego pytania bo jeszcze sobie z tym nie poradzilem czy idzie zrobic zeby otwieraly sie zamki po wylaczeniu silnika.... kolego Simoniak to selektywne zamykanie i otwieranie drzwi to nie to:( po kolei pilotem mozna otworzyc drzwi w tym selektywnym
 Tytuł: Re: [Exx] prosba o przetlumaczenie programu NCS Expert
PostNapisane: 18 stycznia 2012, 19:19
Moje BMW: e46 330d
przez jaki system to robisz?
Użytkownicy przeglądający ten dział: Brak zalogowanych użytkowników i 96 gości
